Any suggestions of exhaust upgrades?
Today, on a whim, I decided to drop my 2002 XK8 off at my muffler shop and had the center resonator? Removed and replaced with straight pipes. Made a HUGE difference.
But I want a little deeper richer growl. He suggested I remove the front two mufflers, and replace the rear with flowmasters. Is a pretty inexpensive option but I'm not familiar with this area of mods, I only know what I like when I hear it. My XF has a SUHWEEET growl.
Anyone have an inexpensive suggestion for getting a deeper growl?
Fresh off page 2 for your reading/listening enjoyment! https://www.jaguarforums.com/forum/x...-video-104393/
philhef (11-06-2013)
So my question now is if its better to remove the rear mufflers or front mufflers. I too am doing this is stages and if I get the sound simply by removing parts, then I'll stop. My muffler shop said he almost took the two small front mufflers off. But now I'm wondering if the rear mufflers may be better to start with.
I'm going to sound crotchety here, but...
I'm confused as to why a thread on this topic is started anew about every 2 - 3 weeks. There is a lot of GREAT information already posted on this forum about exhaust upgrades, parts, sound clips, everything one could hope to find.
Starting new threads on common topics without first using the search function just makes it harder for future members to find good information. For instance, a search on the XK8/XKR forum this morning for the words "exhaust" and "upgrade" brings 117 different threads. Isn't that enough?
Rant over. Good luck with your project...I'll be doing the same in about six months.
I'm confused as to why a thread on this topic is started anew about every 2 - 3 weeks. There is a lot of GREAT information already posted on this forum about exhaust upgrades, parts, sounds clips, everything one could hope to find.
And there are a lot of new members that may have experimented with the option I am looking for and haven't posted their results yet. I've also used older posts to source info, but rarely get responses from those old posts as most of those people have moved on to other things and obviously don't have the time to answer questions on that topic anymore.
And finally, when I search threads, I tend to have to weed through a lot of unrelated threads and on my iPhone, it's difficult to navigate quickly.
Sorry if my thread got in the way so I'll try to do my homework before posting.
Received 6,366 Likes
Maybe because I've been told by my painter, mechanic, audio shop, and trim shop that I am the most pain in the bum picky customer they've ever had!!
But to my credit, they say I have one of, if not the most perfectly modified and maintained cars they get to work on!! Of course I'm sure their wallets like seeing me driving up.
Not to say I don't do some really bad things while getting it right!! (As most of you have seen!)
Just FYI (especially to those new to the forum), you will get very mixed and often confusing results using only the forum search engine. I always use google with the question or topic I need plus "jaguar forums" added. This is a much better search technique and brings back more focused results.
A typical google search would be, "coolant leak jaguar forums". The first 5 results categories in this search are specific to this forum. Of course you could add XK8 to dial it down even more granular, but many times the XJ lads have some good info that works for our cars as well.
Norri (11-07-2013)
Exhausting
Hi All,
I know this has been discussed to death but just wanted to share my 2 cents worth. I removed the large center muffler and the two small pre over the axel mufflers. The cat purrs now! The only negative is at real high RPM it has a slight crackle. No, droan though. Maybe baffeled exhaust tips would fix it. I however do have a question: I have read comments that installing an H-Pipe can increase low end torque. Anybody try it? Is it enough to feel?
Hi All,
Second, yes it's been discussed to death and the the "unnecessary post police" may give you a citation. I got one for posting the same questions!! Lol
Ive spoken to Arden on this issue.
The 4.0 is a small displacement, but high compression, DOHC engine, that has great mid-range punch.
The problem with our power, is the exhaust pipes that go over the axle, cringe flat to almost, an inch or so choking the cat, and
2.The intake air duct that goes from air-box to fender, is extremely restrictive.
A k and N air filter ain't going to fix that.This will require your fender's existing hole to be enlarged to the new 90degree elbow, you would run there.
The airbox can be enlarged, simply by cuttin or heating the tube up and letting it burn itself in.Then RTV seal.
3.Then install your K and N filter.
Yes this is a proven solid 20+HP and 13lb torque gain, you notice immediately, for less that a few hundred bucks, depending on your exhaust shop labor guides.
Gregfromuk (11-08-2013)
Exhaust Upgrades
There are a lot of good upgrade systems out there but one option you should consider a lot is whether to remove the crossover muffler or not. Yes is does help increase power but removing it increases cabin noise a lot. If that's not a problem go for it. I found removing the second muffler and changing the third gave me the extra power and sound I liked without increasing cabin sound. Good Luck!
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
Dickie_L_J_O
09-13-2015 07:44 AM
WTB[SouthWest]: Mina Gallery X350 exhaust
XJ8JR
09-11-2015 12:31 AM
rachelstr
09-03-2015 12:59 PM
