Any way to program a remote yourself?
Old 02-11-2008, 08:06 AM
rscultho's Avatar
Default Any way to program a remote yourself?
Any way to program a keyless entry remote yourself? Some cars have a procedure that allows it. I have an 02 XKR 100.
Old 02-11-2008, 07:01 PM
Default RE: Any way to program a remote yourself?
All correct but for the 5 beep thing. Once is enough. Also remove key from ignition after programming to test.
Old 02-12-2008, 06:47 AM
rscultho's Avatar
Default Thanks...
one more question...
I have one transmitter that works and one new one. Will I have to program both or just the new one?
Thanks again!
Old 02-12-2008, 07:01 AM
Default RE: Thanks...
Both at the same time. When you get to the pushing button on the remote, push onethen the other.
Old 02-15-2008, 08:12 AM
rscultho's Avatar
Default Success!
Worked like a charm!! Thanks for the help!!!
Old 02-15-2008, 08:48 PM
Default RE: Success!
Anytime.
Old 03-13-2010, 04:45 PM
Spillwaybob's Avatar
Hi, I'm new to this forum and I just purchased a beautiful '01 XJ8 VDP which did not come with a remote. I bought one off Ebay and have followed all the programing methods suggested in this forum but still it won't work. On the 4Xheadlight flashing method, the alarm chimes on the 4th headlight flash and then chimes twice after about 5 seconds. The alarm system works fine with the key as do all the other electronic devices involved with the fob. Anyone got any suggestions? Thanks for your help.
Spillwaybob
Old 03-13-2010, 05:40 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
How did you determine the part number of the correct remote? There were at least 2 in '01.
Old 03-13-2010, 06:44 PM
I didn't, the company I bought it from said it would work on my model/year. The number on the back is XR83 15K601-AA. If it is the wrong one, I hope they will swap it out, otherwise that's $30. down the tubes. Thanks for your input.
Spillwaybob
Old 03-13-2010, 07:30 PM
test point's Avatar
My suggestion is that you contact a Jaguar dealer and ask for the correct part number based on your VIN.
They are not interchangeable.
Old 03-15-2010, 05:12 PM
Test Point, I took your suggestion and visited my Jag dealer and found out a few things.......none of the numbers on the back of the transponders are Jaguar part numbers so he couldn't tell me anything about the one they sent me. He did, however, give me the Jaguar part # for the correct one for my VIN #. I emailed this information to the company I bought mine from and they agreed to try and find me the correct one. Seems there are several for year '01 xj8. Thanks for your input and will keep the Forum updated.
Old 03-18-2010, 09:06 AM
Problem not resolved yet......the company agreed to refund my money so I returned it to them. In the meantime, I have written the previous owner of the car asking him to send the remote to me if he still has it. Before I purchase another after-maarket one, I,ll wait for his reply. Locking/unlocking the car with the key is not so bad anyway. When I have more news, I'll let you guys know. Thanks for listening.
Old 04-03-2010, 01:40 PM
Discount Remotes got me the correct transmiitter for my VIN #, I programmed it according to the instructions in this Forum and it works fine. I got the part # from the parts man at the local Jag dealer, and that # appears on the transmitter.
I couldn't have programmed it without the proceedure instructions from you guys and I greatly apprecite your help.
Spillwaybob
Old 04-03-2010, 11:18 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Another satisfied customer! Good job spillway, and thanks for the follow up!
Old 07-13-2011, 09:32 AM
joyroadboy's Avatar
i ve tried numerous times to get my fob to work again but no luck i get the flashing light on the gear shifter but no sound or horn when i push buttons on remote this is on a 2002 xkr the remote was working until disconnected battery now it doesnt do anything any help would be appreciated
Old 07-13-2011, 02:39 PM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
Do you have more than one remote? If so, try the other remote. I've disconnected my battery numerous times and I've never had to reprogram a remote.
If you just have one remote, try changing the battery in the remote. It might just be a weird coincidence that the car batt and the remote batt died at the same time. I'm not quite sure if changing the battery requires the remote to be reprogrammed. Just follow the procedure above if the remote doesn't work after you've changed the battery. My car came with no remotes. I bought two on eBay for $25 or so, and the procedure above worked perfectly for me. In fact, I think that's how I found this forum.
Old 07-14-2011, 07:57 AM
joyroadboy's Avatar
thanks ive figured it out the stupid remote had been in my pocket for so long it got squished and the battery wasnt making contact with the terminals so a lil bending and it worked. now will a remote from a 97 xk8 work on my 02 xkr or are they different, and if they are different what do i look for in a replacement
Old 08-08-2011, 09:16 PM
Crispy's Avatar
FYI, I bought two 4-button remotes on ebay for 25.00 a piece, shipped. My original remotes are LJE2610-AB and the new ones are XR83-15K601-AA. I paired them all with the car using the high-beam method described above. They work like a charm!
Old 08-09-2011, 12:46 PM
H20boy's Avatar
sweet. A good cross-reference success note!
Quick Reply: Any way to program a remote yourself?
