Any way to tell if I bent a valvestem?
At 90K miles the secondary tensioner on the passenger side failed. The guide ate the chain, which failed. Common enough problem, I know, but since it happened when attempting to start the car I am wondering if there is any way to know if the valvestems are OK short of pulling the head. I replaced the tensioners and chains (all) and the car is running really well. I took it to a mechanic for a compression and visual inspection. Their camera shows no head damage, the compression is good in all cylinders and when they pressure tested them with air, they all held well. Unfortunately my very nervous ear imagines a ticking noise I did not remember coming from that side. I am at a loss how to proceed. With all the tests good, is there any other thing that could be causing the noise? Suggestions anyone. I would hate to go thru the expense of pulling the head just to have them look and say no problem.
Valve stem is ok hence the good compression.
But you will have a damaged valve tapped which causes some clearance between the tappet and the cam resulting in the noise.
You can rev up the engi e hoping that more oil pressure will built up making the hydraulic tappet to further extend, if not already at its maximum.
So either find the damaged hydraulic adjusting tappet and replace it or just live with the noise.
pkispert (10-01-2011)
a new valve hydraulic valve adjuster/tappet is not too expensive, around 60 USD I guess.
but you have to find out which one it is first. you have to check the valve clearances, it is the one where there is clearance/play underneath the cam when it is not in the lifted position.
Then, if you are lucky it is one of the exhaust side ones, so you can easily lift the camshaft, and replace the tappet.
if it is on the intake side, then you have a problem and you have to take the timing chain off first.
but, it won't cause any significant wear and tear to your camshaft and valves unless you plan to do another 100.000 miles.
pkispert (11-25-2011)
well have a look at the second post here: https://www.jaguarforums.com/forum/x...g-sound-33961/
also if you look at this: jaguar.telko.ru/AJV8%20engine%205HP24%20transmission.pdf
On Page 11: "Steel shims in the top of the valve lifters enable adjustment of valve clearances."
so, not an expert but seems like no hydraulic valve clearance adjusters/tappets ...
BTW: I'm posting here because right now I really need to find out.
The 4.0 V8 has shims to set valve lash. I can't remember any Jaguar engine that had anything but mechanical lifters.
At least the shims are on the top of the tappet with this engine!!!!
Here is a TSB for the V6 engine but the V8 is done the same way if you don't want to remove the cam.
bob gauff
bob gauff
The following 3 users liked this post by motorcarman:
thanks to all
Thanks to all for the information. To update the situation, it has been just under 3K miles now since I replaced tensioners and chains. The noise has not gotten any better, or any worse. Performance has continued to be fantastic, in all power ranges and speeds. I am going to continue to live with it until there is another reason to dive into that side again. Again, thanks for the advise on this, as well as the other threads on replacing chains and convertible hydraulics. This forum -and the readers- are great. Phil
xjrjag
09-27-2015 01:53 AM
