Any of you guys use this? Ultra gauge
Hello Steve
Sounds like you are coming to terms with it well.
Forgot to give you the hint to force 9141, so long ago since I set mine up.
I have my alarm set for 105°C to err on the safe side. Then if it goes off I can get it out for visual monitoring. As I keep mine in the centre arm rest (tucked the cable out of the way through dash etc), unless I am wanting to monitor or check something.
If I remember correctly I turned off the alarm for pending trouble codes, as it kept alerting for P1111, which is not a fault condition.
I have been using a ScanGauge for years. It has the same functions as the UltraGauge, but is a bit easier to mount. I mount mine on top of the steering column cover with velcro. I have an off-on false alarm about an intake vacuum leak. It throws a code. In fact, there is no vacuum leak that I can find. My wife drives the car mostly, and she simply resets the CEL using the ScanGauge.
abonano
25
09-25-2015 10:43 AM
