Anyone ever removed the lower steering column
The following 2 users liked this post by motorcarman:
jamdmyers (06-28-2016),
RaceDiagnostics (06-28-2016)
OK, decided to have a go at this tonight.
I was able to get the lower steering coupler off in just 5 mins due to having it well greased from last time it was off.
I then detached the top end but had to knock it off the spline as it was pretty tight, but no big deal.
The hole that it goes through.
Trial fitted the new unit, but it is to tight to pull fully on to the spline.
Took it off again for a closer look.
Tried to open up the coupling a bit to help it in but no joy at all.
So the options are take it out again and force the coupling open more, but risk not being able to get the bolt back in or?????
Any suggestions on how to get this on?
cjd777 (06-28-2016)
I had to do this on mine also as I was getting a slight looseness from the column. Repaired it by greeting thoroughly and liberally where the shaft slides in and out of the assembly once the unit was out.
Putting it back in is a bitch.. i did open the splines up a little more, make sure you are getting them in line correctly and apply a little lube to aid going in. And apply a little force also as it will go, just needs gentle persuasion.
The hardest part your yet to find, it was for me, was getting the rubber boot over and back in place when it is all connected up, Mine is kind of half done, so i still get a little noise from that area.. I should revisit it one day, when it stops raining...
RaceDiagnostics (06-29-2016)
BobRoy (06-29-2016),
I had a whale of a time trying to get that inner coupling up onto the steering column spline. What I found was that there is a spring type retaining washer on the outside of lower column, just where it disappears into its housing. It was preventing the shaft from sliding farther through the housing. I needed to grip that retaining washer with a pick (or something similar) and shimmy it lower on the shaft. Then the shaft was able to slide further through the housing, into the cabin, and onto the steering column's spline.
I remember that bit now... trying to stop the column moving away on its own accord... very annoying.
I used a large flat head screw driver and the coventry screw driver (hammer) to prise open... worked for me but i didn't go mad on it.. just gently then try again, gently then try again...
Good luck, especially the boot separating the interior with the exterior which the column goes through.. think about how to tackle that as you get the shaft through, may save you some time if you get it right... if I look back now I would have spent more time on that
OK, I spread the coupling a little bit and got it to slip on and get the bolt through without further problems.I massaged the boot from beneath and got part of it to come through to the correct side.Then massaged it more and used a small hook tool to get it all through.I put lots of grease on the splines to prevent future corrosion, then it took a couple trial fits to get the steering lined up perfectly.Great to be driving again with no slop in the steering.
bob
Well done!!! I think I need to go back and now put my boot on... pull it through... I was worried about using a hook.. just in case it ripped the rubber... So the screw driver opening it up did the trick eh... same as i did... I had patience for that part but not the rubber boot part! Easy enough job if you don't get angry and don't mind your back being put out by the contorted positions you get into...
