Anyone with Parrot BT in armrest?
Anyone with a Parrot Blue Tooth connected up to the connector under the arm rest care to try something?
I think I need the telephone module to make the parrot work. If you had a Parrot Bluetooth installled by connecting three wires to white/yellow connector under the arm rest, would you open your trunk, lift up the spare tire cover and disconnect the two connectors to the long module mounted on the back bumper wall on the left side and then see if the Parrot works?
salP3082
09-25-2015 05:07 PM
280zx-turbo
09-10-2015 06:29 AM
