Armrest not closing tight
2001 XK8 convert. Long story made short, I took apart the lid of my center armrest in order to remove the old cell phone assembly. I thought I had put it all back together correctly, but now the armrest lid doesn't close tightly. I removed and reinstalled the latch thinking perhaps I had not put it back with the lip facing in the correct direction. Still didn't close tight. I've tried adjusting the screws in the inside rear of the armrest and adjusting the lid-stay arm. Still doesn't close tight.
Now I wonder is the arm rest supposed to close tight, with a noticeable click? Is there some trick to installing the latch -- angling it some way, perhaps, so it fits more secure into the notch in the arm rest?
This is no big thing, but it bugs me.
Your not dense, I had a devil of a time trying to figure out how to explain the repositioning of the latch, without writing a book. My brevity may have caused the confusion.
Take out the two screws holding the bottom portion of the latch and two pieces will come loose. The large piece that the bottom part of the latch comes through and the latch itself. With those two pieces taken out you will see what looks like two ears of the armrest bottom liner with holes in them, the screws that were taken out also go through those holes. The bottom part of the latch should then be inserted below those ears and the large hold down piece put back in place.
If the bottom part of the latch is inserted on top of the ears it will stick up too far and its shoulders will stop the top from lowering far enough to latch.
Let me know if this helps.
woox4 (01-23-2016)
The cover in front of the armrest
Although I am not having a problem with the armrest, I do have a problem with the cover over the lighter and ashtray not staying closed which is right in front of the armrest. I took the screws out of the armrest latch and removed it so I could see behind to determine why it won't stay closed. The space is too small to really see anything. Obviously it does not operate on a magnetic catch. Do you know how it's supposed to operate? I don't see anything else I can loosen to get back in behind it to really take a look. Any advice on the next step?
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
