ASC and TRAC Error need a little more Info
The car fixed itself Friday morning when it saw me coming at it with tools and contact cleaner. I went a head and cleaned the three plugs on the TB and disconnected and re-installed the ABS unit connector. All was fine over the weekend and I finally got to drive it to work for the first time in 3 months. This thing is worse than owning a horse! Ha! Ha!
No, they are easy to get at once you remove the intake plenum. I would suggest replacing the battery first. I have no explanation why mine started working correctly. All I know for sure is disconnecting and reconnecting the battery always fixed it for a short time, old or new battery.
Something else I had not mentioned before is I have to pull the car in and out of my garage every time I ride my motorcycle and I ride my motorcycle a lot. This may have ran the battery down to the point the system check was not happy. I know the new battery was not charged correctly at first and I did charge it a couple of time before things started working correctly. Battery's are like sponges when it come to charging them, maybe I finally got a deep charge on it?????
jimforrest (uk)
02-28-2019 06:42 PM
