ASC Trac issue
NOOOOOO!!!!!!! Don't spend big bucks on that without trying the cheap stuff first. Check the battery. Take it to an Autozone or Advance Auto Parts and they'll drag this little cart out to your car and load test the battery. It might show normal voltage while just sitting there, but when they put it under load it might show that the battery is bad. Also, check the connections on the battery. Take off the battery leads, clean the terminals with a wire brush and then put the leads back on the battery. Check the ground wire to make sure it is securely attached to the chassis.
Your problem seems to be relatively common judging by the number of times this question is asked here on the forum. And more often than not, the problem is battery related. These cars have very sensitive electrical systems, so it's in your financial interest to make sure the battery is up to snuff before spending big bucks on a throttle body.
Read this before you purchase a TB http://www.gusglikas.com/AutoRepTB.htm If a TB is necessary then look at reconditioned ones and save a few bucks. Problems have been known to exist without throwing proper codes. As for the ABS / Traction Control You need to check and clean your sensors and sensor plugs first. A repair for a common problem in the ABS module is available http://www.gusglikas.com/images/Auto...e%20Repair.pdf but check your sensors and connections first. If you look you can find a nice post on the sensors and ABS module in the xk8 posts
I do agree to have the battery checked first.
