ASC/Traction Control Message
Periodically I get the Anti-Lock brake symbol lit up with the message "ASC/Traction Contol Not Available" (or something like that). I get it when I start the car and can turn it off by restarting it after I have driven a mile or two. Sometimes (rarely) it will pop on when I have been driving and sometimes not come up at all. In fact the whole issue went away for a few months before it came back again...
Thoughts?
Thanks in advance...great forum.
Thoughts?
I had the battery "Load Tested". It showed plenty of cranking amps and 14.05 volts. I was told that as long as its above 14 volts that the battery isOK. Given the sensitivity of these machines is that true?
In the meantimne the error message is not re-setting as readily as before. It is on 75% of the time.
Thanks in advance!
Thanks in advance!
Received 2,192 Likes
without codes to see what the abs ecu sees as a fault is like fishing without a pole, its guessing at best. but heres a guess, if its c1095 pump motor, this is a ecu malfunction and you need an expensive ecu, the good news is that your abs works fine with the light off, and it doesnt have to be replaced until the light stays on, or you get tired of it coming on
I'd suggest cleaning the wheel speed sensors first, as Lew suggested...thats a freebie. If you're running the stock brake pads, those things are incredibly dusty, accumulating everywhere..hence my message center appeared several times when I first got the car. i've sinced pulled the wheels, cleaned everything in the wheelwells, replaced brake pads, and the message has never come back.
If you've got a message after cleaning, get the codes read as brutal recommends...that'll tell you at least which wheel is giving you grief, if its a sensor or other larger problem.. and you can start nailing it down from there.
philwarner
43
09-10-2023 11:30 AM
abonano
25
09-25-2015 10:43 AM
Johnken
09-15-2015 05:46 PM
