Auto adjustment
Auto adjustment
Does which key/key fob you use effect which memory button the auto control for the seat and steering wheel adjust to when you put the key into the ignition? I just replaced the tilt motor in my steering wheel and this is the first time it has worked properly since I have had the car. I set the memory button #1, but the auto return seems to go to the memory button #2 setting when I insert the key into the ignition.
danke
10-03-2015 09:31 PM
3jagfamily
10-01-2015 01:49 AM
