Auto Dimming Rearview Mirror Replacement
#242
I sent mine in a couple of weeks ago with the mirror, wire, and trim exactly as it came off of the glass. It was all returned and now works great. I think they fix YOUR mirror now. If that can't be fixed, and there is no other old mirror like yours laying around their shop that they can use to replace your mirror (likely now), they tell you yours can't be fixed and charge the $15 bench fee. If they had a spare, you might get someone else's mirror as a repaired replacement. I wouldn't worry, as it looks like you have even removed some of the plastic trim from the mirror after it was removed from the windshield.
King Charles (09-19-2015)
#243
#244
#248
#251
Pictures from the First Post... could not edit and insert.
Here are the pics for the original post. The post is so old, the edit function is unavailable, e.g., no edit button. Maybe someone with access to forum programming could insert them into original post. It would certainly help someone viewing this thread for the first time. gordocatcar
#252
In a world without coincidences I wouldn't be able to say THANKS GORDO for reposting the pics as well as the original post. I finally got around to this after a series of other issues (my wife is calling my car my boat lately) and came here first to review info.
I got lucky in that mine slid off quite easily.
A couple of observations:
1. After dropping the console I unplugged it and set it aside to get it out of the way. Made the rest easier.
2. I have the sensors and the sensor disc came off the windshield as I had not unplugged it, but I unplugged it and stuck it back on right away and the tacky adhesive they used grabbed immediately.
Packed and ready to go. I did take a couple pics and sent to Stacy. She noted the bottom of the mirror case has some melting damage from the leak. I asked if that would be an issue on their end. Here is her reply:
We do have to grind it a bit, but we typically have successfulrepairs in mirrors that have had this occur J
I've attached the photo here so you can see what I mean. Click on it and it's easy to see.
I'll report results later.
#253
Received 6,339 Likes
GordoCatCar (11-12-2015)
#255
It's Back!
Mirror came back yesterday and went back in in a couple of minutes.
Looks great and operates perfectly.
FedEx even delivered it a day ahead of schedule, so just in time for this weekend I'm good to go.
Hat's off to Sybesma and the great write-ups on this forum!
#256
Ok, so I've been extremely slow on this, but I finally pulled my mirror and got the information to send for a replacement mirror.
One note, if your car is equipped with the rain sensing wiper option, I recommend removing the bottom plastic cover so that when the mirror is removed, the second plug can be easily removed.
Here is what the mount and plugs look like on my 2000 XK8 equipped with automatic headlights and rain sensing wipers.
This is the mount and the sensor for the rain sensing wipers:
This is the connector on the roof that the mirror plugs into:
Here is the back attachment on my mirror (which is the same mount as Gordo's) which also shows the additional plug for the rain sensor:
Might it be possible to make this post's pictures available again, as Gordo's were recently?
Thanks.
#257
Thanks to all the posters and their contribution to us backyard mechanics, this thread on mirror replacement has been great to read. Now, enough of the reading for me and onto the doing, I will be having a go at removing the mirror tomorrow. I will let you know how it goes and contribute my two cents.
Thanks again.
Thanks again.
The following 3 users liked this post by Jandreu:
#259
What a difference!
I finally yanked my mirror and sent it off to be refurbished. It made a huge difference. The auto dim works well, and fairly quickly.
Before
After
Random notes:
Tom
Before
After
Random notes:
- The whole job went pretty smoothly, and none of the windshield nightmares occurred. This thread and accumulated forum experience definitely helped my comfort level.
- You have to pull the overhead console pretty firmly to get it down. I'm not going to lie: I was nervous since I have broken plastic mounting points on other cars before.
- When re-installing, you may want to go ahead and tighten the screw on the clip. My mirror had a jiggle because it was loose, so I had to pull it off again.
- Sybesma prices went up since August, 2015. I opted for 2nd day delivery and paid $125.
- They received the mirror on a Monday, shipped it out on Wednesday and I got it back on Friday. You can trade more money for more speed going and coming.
- I got used to driving with no rear view mirror more easily than I expected. Having the top down is a big help.
- Other people who drive your car may freak out when they realize there is no rear view mirror.
- Apparently I was used to the "New Mexico landscape" look before the repair. I'm still a little startled when I look at the rear view mirror and I can see a clear reflection.
Tom
#260
My mirror went out as well. I purchased a used one on Ebay for $55 that came out of a 2007 Acura TL. It has the same item # 11530 as mine does.
Only issue is that the yellow connector from the old mirror has 6 wires, Brown,Green,Yellow,Black,Gray, White and the Acura mirror only has 3, black, white and gray. Does anyone know if I just go black to black, white to white and gray to gray?
