auto inguinity scan tool?
when i got mine, i called them direct and they gave me a bit of a discount for ordering both the basic kit and the upgrade.
But i also ordered the Ford upgrade at the same time.
The best thing about this system is it allows you to view codes that you would have to bring it to the dealer to diagnose. That and you can get upgrade kits to read the advanced systems on other makes AKA:Ford:GM:BMW:ext ext ext...
Thanks. They didn't say anything about a discount - but I didn't ask, either.
$500 is a bit pricey for me but I save a bundle each year doing my own work so it's probably worth it. I'd get the upgrade module for the Corvette if anything ever went wrong with the car - it's been absolutely bullet proof for the 8 years I've owned it...
I went to the local auto parts store and picked up an Innova 3100 OBD2 code reader and it works great, too good, on my XKR. It shows me all the codes with details and brief explanations. It also has the built in ability to select manufacturer to get specific code information. I think it was around $125.
http://www.canobd2.com/
the only issue with the in store units is they almost always do not allow you to scan systems other then engine control. the AutoEnginuity system allows you to read the base ecu and with the upgrades allows you to read codes and sensor values on every system on our jags. Worth the money unless you want to fork out reall good bucks and by a vcu.
Dickie_L_J_O
09-13-2015 07:44 AM
2000, auto, autoenginuity, car, compatible, inguinity, jaguar, scan, scanner, scantool, scen, suspension, tool, xj8, xk8
