Auto Levelling Headlights question
When I start the engine the headlights rise and then sink down again.
Just wondered if this is normal. The levelling arms on the suspension appear to be intact.
My dipped beam does appear to be too low.
Could someone please confirm, or not, that this is normal behaviour for the auto system.
Thanks.
Thanks.
Received 2,192 Likes
malbec (02-16-2012)
What's the adjustment procedure?
My levelling is operating OK but the left hand dipped beam is set far too high.
Headlamp Adjustment - HID.pdf
This next one gives a slightly better view of the adjustment screw:
Headlamp Levelling Motor - Vehicles with HID.pdf
jamjax (02-17-2012)
Thanks G;
Does anyone know the answer to this question??
Do you know if this adjustment hex screw works for both the hi and low beams?
Because the hex screw looks like it is on the hi beam barrel only.
Great tip in the HID-PDF that you must have the car running to properly do this.
cheers,
jj
cheers,
jj
Thanks Guys. Listed my new car. Its a 2003 XKR Love it Just had to replace the battery and everything went out of sink. All systems go now. Having some transmissions issues, jurk at stop. Will have the trans fluid changed this week. Looking for a set of 19 or 20 wheels. Have to replace rear top hoses.
Wolfy
05-28-2024 08:06 AM
