auto locks, reverse sensor, convert control
Old 03-24-2010, 01:31 AM
robrtx's Avatar
Default auto locks, reverse sensor, convert control
For no apparent reason, the auto lock system (doors, trunk), the reverse sensor alarm, and the convertible top control stopped working.
Battery is less than 2 years old and I keep on a trickle charger so it is fully charged
Tried disconnecting battery and reconnecting (re-set) which did not fix
checked door lock fuses in passenger side fuse box (appeared good)
Any ideas as to what could cause these problems would be appreciated.
Old 03-24-2010, 11:26 PM
robrtx's Avatar
To clarify, '03 XK8, locks do not work w/remote fob, or trunk release, or alarm, convertible top doesn't open/close. Tried other fobs, new battery in fob, nada
Any ideas where to start would be appreciated
Old 03-25-2010, 06:52 AM
Fjk's Avatar
Fjk
Fjk is offline
A few questions.... assuming you have checked that all related fuses are good.
1. Do the doors lock manually ?
ie: From inside the car will BOTH doors lock when the drivers door latch is pressed in.
--Do doors lock automatically when car picks up speed.
2. Will the trunk open when switch in car is pressed.
3. Will the convertible top raise and lower when using the key in door
Look for a common cause. Keeping in mind there may be a co-incidental failure.
Modules involved are mostly in the trunk. SLCM and Parking Aid.
Could be CAN problem. Vehicle speed?
Wiring diagrams are available. See FAQ Or send me you Email addr. and I will send you one.
Old 03-25-2010, 12:05 PM
robrtx's Avatar
Hi Fred
Doors do not lock manually when locking driver's door from inside.
Doors do not lock at speed.
Trunk does not open with button inside car.
Top does not lower from key in door (but interior lights come on)
Any guidance is appreciated.
BrentGardner
28
04-26-2024 03:08 AM
Jandreu
08-23-2019 11:37 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
frankc
09-01-2015 04:41 AM
tberg
08-31-2015 04:33 PM
Quick Reply: auto locks, reverse sensor, convert control
