Automatic Door Locks - not working
Success!
For the next guy...
This is an easy job, it took me less than an hour.![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Check the appropriate 10A fuse in the passenger side fuse box. If blown, replace. Otherwise move on...
Remove negative lead from the battery. Wait 5 minutes and reconnect. This will reboot the computer. Still no lock actuation? Move on...
Disconnect the negative lead on the battery again andreplace the door actuating system relay.
The door locking relay (p/n LNA6705 AB "Micro relay" black) is located behind the passengers lower facia at the far right. Gain access by removing the glove box (easy, just watch for the wires for the interior box light when removing. Only remove the 2 outermost lower hex screws, not all 4).
The relay you want is in a 2-relay holder far outboard behind a larger single relay.(Remove the larger relay for easier access to the 2 relay holder.) Remove the holder from it's locating tab for easier access to the door locking relay itself.The door locking relay is the one serving theYR,YG,B,NR,NR wire set. (N=Brown)
Replace the relay and reinstall the holder on it's tab. Reinsert thelarger relay and reinstall glove box.
Reattach the negative battery terminal.
Re-index windows (for convertible) and reprogram radio as needed...
You can do this!![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
For the next guy...
You can do this!
MLM
Received 6,327 Likes
Vegas_Jag (11-15-2019)
#28
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
msdg137
09-16-2015 06:24 AM
