Automatic lights
I keep the headlight switch in automatic mode. The lights often stay on for an extended time after I leave the garage in daylight hours. I assume the solar sensor on the dash is not working properly. Is replacing the sensor an easy fix, or could it be another gremlin causing the problem.
walkman1 (08-09-2017)
Hi Stu
If you feel the far side of the mirror you'll feel an indentation. The sensor is in there and when you cover it with your finger ignition on and switch in auto, the lights should come on. Mine has the opposite problem to yours and don't come on at all in auto mode. Removing the overhead light console reveals the wiring to the mirror and connecting an earth to one of them ( can't remember the colour but it's in the wiring diagram ) should switch the lights on. After considering the price of a new one and the risk of breaking the windscreen removing the old one I decided to rough it and switch the lights on and off manually.
It's a hard life.
Pete
Late extra: the wire is the yellow/blue one so I guess that if you disconnect that one with lgn on and switch in auto the lights should go out . this would prove that the fault is in the mirror /sensor.
Good luck
It's a hard life.
Pete
Good luck
Stu,
Think you said the lights are on with ignition off. If so, it can't have anything to do with the sensor in the mirror. It uses on ignition voltage to turn on lights.
Please verify that you have lights on with key out ignition off. I'm trying to think of what in the light switch has battery, maybe the circuit to turn on high beams when you pull back the turn signal lever, before I start suggesting what may be turning on the lights. I'll wait until you verify the question before I dive into trouble shooting it mate.
Bottom line there are no battery wires in the mirror, it's all ingition powered as far as I can recall. Therefore when your key is out, there should be no voltage in any wires at the mirror at all. Nothing in the mirror could turn the lights on KOIO. That's why I ask the question.
If you say Yes then: Do lights go off KOIO (key out ignition off) if you move the selector out of automatic lights?
Does flicking / jiggling the turn signal lever do anything?
You didn't say how many seconds it stays on for. mine goes off instantly, but I wonder - what if the door in the ingition key cylinder sticks open. Could the car think there is a key in ? Might the auto lights stay on until key is "out"? I really doubt it but would have to check.
Ah, look at me trouble shooting before you get a chance to respond. Let us know mate.
John
John
Stu,
John
John
Hi John,
Sorry, you misread my post. What I said was, "My auto headlights shut off as soon as I turn off the ignition".
Pete,
I wanted DRL's for safety, so I took a piece of black electrical tape and covered the mirror sensor so that my headlights come on every time I start the car.
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
Stu
Oslojag (08-16-2017)
