Auxilliary Belt Idler Pulley
Hi,
I need to replace my Auxilliary Belt Idler Pulley (super charger belt) as the bearings are on their way out so after buying part number C2C37064 I found the part was smaller than currently installed.
I spoke to SNG Barratt who said this is because I need to change the belt, mounting bracket and idler too, does this sound right?
Thanks in advance.
Thanks in advance.
Regards
Phil m (05-11-2023)
Thanks for the really useful information Motor, the belt does not look warn nor does any contamination look obvious but I'm going to examine the brakets and check the belt looks correct and then change the bearing in what I think is the defective pulley.
thanks again both.
thanks again both.
rocklandjag
02-25-2015 04:45 PM
JagTheRipper
11-12-2011 04:28 AM
