Baby Got New Shoes
Old 06-17-2015, 12:04 AM
MediaBobNY's Avatar
Originally Posted by XxSlowpokexX
Looks great!!...I bet if you lowered the car just a bit it would look even a bit better
IMHO, what would make it even better looking is the removal of the side rub strips (Less is More). But if that involves repainting, fahgettaboudit (as they say in Brooklyn).
Old 06-17-2015, 10:28 AM
Jandreu's Avatar
That might be a little to dangerous on Maui. Parking spaces on this island are very narrow, XK8 just fits line to line with a hair to spare in most parking lots so the risk of door dings is very high.
Thanks for the suggestion..
Old 06-18-2015, 04:07 PM
XxSlowpokexX's Avatar
I did both....But I make sure to park away from EVERYONE!
Old 06-18-2015, 07:28 PM
ccfulton's Avatar
Received 1,108 Likes on 764 Posts
Later cars didn't even have them. Cost cutting?
Old 06-18-2015, 09:53 PM
Maybe because they will think you are crazy if you park it where it will get dings:O)
Old 06-19-2015, 01:40 AM
MediaBobNY's Avatar
Evolution/perfection of the design.
Old 06-19-2015, 09:52 AM
K.Westra's Avatar
I think the car needs the lower side skirts to pull off the no bump strip look. I actually like the bump strip on the earlier cars. Also, coupes seem to look better without rub strips and convertibles seem to need them to emphasize the long and low look. Just my thoughts on the matter
Jag#4 (06-22-2015)
  #28
Old 06-19-2015, 10:26 AM
Jandreu's Avatar
Yelp, I'm on the fence about the side rub/ bump strips also. I like it both ways so will likely leave them, at least for now.
Old 06-19-2015, 10:46 AM
blindside's Avatar
Soooo... if someone WERE considering removing the side strips, would it require any painting or touch-up? I wouldn't think so as long as you helped soften the glue some with a heat gun and use like a fishing line to "cut" the glue. Thoughts or comments from those that have done it?
  #30
Old 06-19-2015, 12:49 PM
Well you may not like my color however lowered with no strips.....I like
  #31
Old 06-19-2015, 02:08 PM
MediaBobNY's Avatar
You may recall they did the same thing with the XJ sedan (X350). The first two years - '04 & '05 - had them. Subsequent years didn't. It's their way of cleaning up the look IMHO.
  #32
Old 06-19-2015, 04:27 PM
ccfulton's Avatar
Default Shouldn't be a problem
Use a heat gun to soften the glue and it should not be an issue to peal them off. Might need a little polishing but should clean up.
BUT the thing to watch out for is if your car has had paint work done. A less than stellar shop might have painted around them. I found this out when I took an R badge off of my car to replace it... the fender had been painted without removing them!
blindside (06-20-2015)
  #33
Old 06-19-2015, 09:13 PM
Jandreu's Avatar
XxSxX, how much drop do you have and how did you do it. I'm thinking of getting the H&R sport springs with 1.5 drop.
Your tires look close to the fender, what size are the tires and rims. My new rims/tires are about .6 closer to the fender and am concerned about rubbing if I lower it.
XxSlowpokexX (01-27-2017)
  #34
Old 01-26-2017, 07:46 PM
prettybluefin's Avatar
i love your car! just gorgeous!
Jandreu (01-26-2017)
  #35
Old 01-26-2017, 09:47 PM
Anthony8858's Avatar
Wow, Like the look.
The car looks awesome!!
Jandreu (01-27-2017)
  #36
Old 01-27-2017, 04:31 PM
Sorry man I totally missed this. I don't get tire rub at all. 285 out back 255 up front with a 1.5" drop. They were BMW offset rims that I had the hub bored out a mm or two. I used one of those offset calculators and played with the rim size and offset starting at factory. Also the axles out back were shimmed to help with caster camber issues
Rims are Gianelli Puerto Black with silver lip
19x8.5 and 19x9.5 with 285/35/19 and 255/40/19 Maybe it was a 35mm offset? Cant recall at the moment
Jandreu (01-28-2017)
  #37
Old 01-27-2017, 04:32 PM
  #38
Old 01-27-2017, 08:12 PM
CorStevens's Avatar
Beautiful choice in wheels. Looks like a factory optional set. The finish even compliments you car's particular color. What is especially nice is that the wheels look great without drawing the eye away from the car overall. If I had not just restored my 18's, I would do what you did in a second.
  #39
Old 07-11-2018, 06:31 PM
bcprice36's Avatar
Jandreu,
I like it!
The Top is sort of a Dark Green....Wonder what the Grey Wheels would look like if they were that color Green? Just a thought.....?
Billy Clyde in Houston
Jandreu (07-11-2018)
  #40
Old 07-11-2018, 10:46 PM
Jandreu's Avatar
Originally Posted by bcprice36
Jandreu,"
I like it!
i like the gray as it accents the Dorchester grey on the trim. Mines an 03 starting in 04 Jag switched to a tan top on the Seafoam green cars, also went to a pearl finish I believe.
Quick Reply: Baby Got New Shoes
