Back box removal..too loud ??
Considering removing the back boxes ,not expensive the pipe is about £30 ( $ 36 ) bend it myself and tig weld. BUT having listened to recordings I know under full power you get a nice growl but is it loud when cruising at about 70MPH...dont want a headache ...( ie the wife moaning). did think of just changing one.
Timeisrelative (08-20-2022)
The following 2 users liked this post by Kuddlesworth:
Pistnbroke (08-20-2022),
PKWise (08-22-2022)
Thanks for that ..I could buy at about £200 but why have the TIG and not use it .
The bends are at 170mm from end 117 degrees and 210mm from centre of first bend 15 deg.
Its all in the same plane so you can lay it out on the floor. Cut at 30deg rotate gives 60 deg.
I got some stainless end trims for £6.99 pulled out the innards and they are perfect.
My ‘96 XK8 came with a Paramount system which only has a custom centre silencer and straight piped from there. Thought it was overly resonant for the first 9 months or so and tried all sorts of extra insulation and lagging until I discovered it had been fitted hard against the floor pan in one place and the whole structure of the car was resonating in sympathy - d’oh. Ten minutes work with a crowbar gently ‘persuading’ it to take a slight detour made all the difference. Most tolerable now!
On my ‘02 XJ8 I’ve pretty much done what you’re proposing except I don’t have the welding gear so bought prefabricated stainless elbows and straight sections to straight pipe it from the back axle. Still very refined but just a bit more v8 burble at the back. My conclusion from all that? ‘Go for it’ 👍
gerardbooth (08-20-2022)
Couldn't find anything. My car is fine at any speed just not at around 3000rpm. I think it's just how my exhaust is really.
I'm looking at changing just the over-axle section - Adamesh Stage 2. I think the full stage 1 and 2 is a bit overwhelming and I'll get grief from wifey, so my thoughts are to do the stage 2 only, get a nice borp and hopefully release another 20 or so horses at the same time
Thoughts?
Thoughts?
rod9669 (08-21-2022)
I'm hoping for a nice Welsh Barritone note - pleasant to the ear .. Even though Drakeford is trying to stop us driving, there are still some nice national speed limit roads around, if you know where to look.
Cheers guys, I'll get my local exhaust place to fit the stage 2 and if I fancy it later I can do the rears myself
Interesting. My boom was at about 2,300rpm but wildly exacerbated by the contact with the shell of the car. Just returned from a quick blast in the old girl now and can confirm that there's generally more sound than in the cabin than with a standard exhaust but also that there's no boom and that, for my tastes, it's perfectly acceptable overall.
Timeisrelative (08-21-2022)
(147) Rolling Thunder. Jaguar XK8 recorded on 3 different exhausts. Standard, Stage 1 & Stage 2 Adamesh - YouTube
I fiddled about with the exhaust for a while when I first got my 99 R coupe. That terrible 5 box system on the early XK's was just awful and the first replacement needed...so much squashed piping and back pressure. I got the end pipe system to take out the mid and back boxes, but it sounded like a tractor so ditched that and ended up getting a full Cat back stainless system from Poweflow for £600 all in and fitted. It has the first muffler from the engine and 2 back boxes. It sounds great and a good compromise to reduce the back pressure and growels without being stupid loud. 2.5 inch pipes throughout... I think 👍 That was 12 years ago and still doing great.
gerardbooth (08-22-2022)
If you 'cut and weld' then it's certainly a nice little project. I don't have proof but it seems reasonable that smaller angle changes will yield better gas flow and sound.
I am planning on going in the complete other direction...
I think the pipes from the mid silencers back are 2 inch pipes. Under axle. No rear silencers. I drove about 350 miles highway for the first time early summer.
By the time I did my thing up and down the hills in Western Massachusetts,,, highway there and back home again, I was ready to SHOOT the car. Top down or up,,,, the DRONE was/became unbearable... Hard to talk with my lady in the car.
NOTE - I am an old fogey and an old soul. Slow-ish casual driver. I don't like noise, generally... That's just me.
Sometimes the sound coming out of the car is/can be just SWEET without the rears,,, but sometimes - even local driving - it can be toooooo much.
It has to be a preference thing, for each his/her own.
I'm looking for a non full OE silencer weld in muffler solution as we speak. Any suggestions will be taken.
rod9669 (08-23-2022)
