Back box removal..too loud ??
So, laugh if ya want. I literally just had to poke my head under the car, sitting out front waiting to go to work, to have a look. One would think, considering all the time I've spent under this damn thing, I would know, blind.
The CATs are after market. The body of the CATs are very small in comparison to the OE. From there, 2inch pipe, looks like the combined front center muffler/silencer is deleted and two 2inch pipes run directly from CATs/downpipes to the mid silencers. I believe there is an X pipe set up just before the mids.
From the 2 mid silencers, as apposed to bending UP (towards sky and OVER the axle) the pipes (2inch) kick down towards ground and go UNDER the rear center area of axle/diff/subframe (hence under axle) getting pretty close to the ground. They hang there supported by the rear exhaust hangers and downpipe connection (I think).
From there, a little kick back up and away from center line of car with a straight shot, 2inch pipes, out of the back for the car.
Two 3 inch tips at the end of the exhaust... The dude did a good job - I can't take credit. Clearly, can't even describe it.
At 70, foot barely on gas and cruising/gliding the set up can be almost silent. Give her moderate peddle and it's loud, accelerate, loud, even cruise down hill, no gas, can be loud. Definitely loud from a light, I get looks. For short rides the noise is not a big deal. Longer drives (which I like) top down, for me, it's just toooo much and won't due. I will have to do something.
I hope this helps
I decided to delete the last 4(2 per side) mufflers on my '06 and replace the crimped 'over rear axle' pipe. I had a local muffler shop that I had used do the work as he has a mandrel bender and does great work. We decided that if the noise was too much, a pair of replacement mufflers could later be added behind the rear axle.
I have had no problem with the current sound(except 80 yr. old neighbor who says it sounds like a 'helicopter'?). I have had some drivers follow me to a stop to ask what I had in the car. Some say it sounds like a mid 60's muscle car. I am pleased with the sound, but each to their own.
