Bad Headlight Causing Failed Emissions?
I've got a 2003 XKR coupe with 87k. Tried to get emissions done and they said their computer can't communicate with XKR. Went to another shop, same thing. Took to dealer and they say entire ISO network down. They then traced that to a faulted right front headlamp module and now want to replace the headlamp. Does this make any sense?
It is conceivable. The headlamp leveling module is on the same network segment.
Chances are if it is simply unplugged it will allow the emissions test to proceed, but you may want to observe if the headlamp position one of your lamps is likely stuck at is going to be a problem for you.
Richard_gib
09-12-2015 07:08 PM
