Bad shock towers in rear-2006 X8
They were referring to the shock mounts. They and the isolators fail eventually as they are a dense foam. The lower shock mounts should probably also be replaced while the shocks and springs are out.
The parts are not expensive, less than $200, I believe, but it could take up to ten hours depending on how they do it. I recall a procedure that cuts the time in half, and someone will probably be able to reference that for you.
FS[SouthWest]: Shock Absorbers (ACD) 2001 Jag XKR
2001 XKR
05-25-2016 09:41 AM
terrylcook
05-20-2016 03:29 PM
