Ball joint bad?
1 .cost of 2 ball joints on eBay (standard OEM manufacturer, made in EU) $50 shipped.
2. Labor was a bit harsh, took me 1 hour on one side and about 40 minutes another, with replacing upper bushings.
3. You will need to buy your own press at Harbor Freight ($150), or take control arm to any car service to get old ball joint pressed out and new ones pressed in, no more than 1 hour labor.
Pic. attached.
Abby's Guy (03-26-2012)
If it's the lower ball joint, as the OP stated, then it's a little more involved. You have to take off the lower control arms, and to take them off you have to drop the steering rack. If you don't want to do it yourself, the parts aren't that expensive and any decent mechanic could do it in less than two hours.
Having said that, If the place that told you that it needed to be replaced is the same place that quoted you the astronomical price, I'd question whether or not the ball joint is really bad. There are other suspension issues on these cars that are more common. Bushings and shock mounts are much more likely to go bad before the ball joints.
Last edited by Reverend Sam; 03-13-2011 at 12:38 PM. Reason: Grammar. I be a grammer stickeler.
Having discussed this subject at length with seasoned Jag mechanics the word is that lower control arm ball joints can be replaced but it is often quite difficult under the best of conditions. Unlike the upper control arm ball joints that are received into the control arm straight down, the lower control arm has a complex angle and the ball is recessed at the head making it very difficult to hold it in place while pressing old out and new in. The recommendation is to replace the whole control arm. I am also told that unlike the upper control arm the lower control arm bushing are molded rubber and metal and they are rather stiff. As such, they are much more difficult to remove and replace. Having viewed these directly and observed their replacement I would agree that replacing the lower control arm with the ball joint is definitely cogent advice. If you can't afford the new control arms try to find a suitable used replacement.
Hope this will be helpful.
Tim
Tim
Please reply with price, specific info about the parts, delivery, etc.
My email is: dmmurphy422@gmail.com
Could you email me pricing information for two control arms (convertible XK8 1997) ?
ferrerjulio@yahoo.com
Thank you
Thank you
Hope this helps ,
Nik
I read though this and decided to attack the bad lower joint I had... you cannot do the job with regular installation tools. I ended up turning a piece of bar stock and tack welded (with a space) to the back of the lower arm to be able to press against something. the tack welds were more "*****" secure to the bar stock and lightly tacked to the arm to reduce heat transfer and to be able to cut it free after the new joint is installed. this trick and the "cheapo" press from Harbor Height it went quickly. I did take a picture if there's any interest. the British make easy cars to work on but you need to stop and ponder it over a pint before proceeding.
JagBrian
09-21-2015 07:17 PM
