Battery 97 XK8
Removing the battery will reset all systems in the car but that is not a bad thing. Windows will have to be reset and the ECM/TCM will have to trim out fuel and shifting but will do so automatically.
A couple years ago I was shopping for an XK8 to replace Black Beauty that died in an intersection. Of about 8 cars that I looked at, only 2 had the vented batteries. The correct battery has a vent tube toward the front and a small hose vents the hydrogen gas through the floor board.
The release of a highly explosive gas into the sealed space of the trunk is a bad thing.
You will need to do the reset. To do this you push the window down button and hold until you hear or feel a click. Then push the window button for the window to close and hear or feel the click. This should be done when you are in the car and the door is closed. The window should operate properly by opening a slight bit when the door is opened and close when the door is closed.
Seems my battery is getting weak.
Last week, came back from a one-week business trip, and the car almost didn't start. Windows lost their programming. After that, all ok.
Tonight, went to dinner, came back to the car, and it was in Park...no crank, only dash lit up w/ the radio. Moved the gear shift to N and it fired up. Figures.
Well, my mechanic (British Auto Specialists) thinks the no-start in Park is due to a failing switch in the gearshift assembly, gives me a little hopes in that if it is a 'rotary' switch, there may be an adjustment that will save me some coin. Instead of hijacking this thread, I'll start another one of my own.
#28
Just replaced my battery with a Duralast battery from Autozone, model 49 DL, came with the vent tube attachment right in the center facing quarter panel, easy swap out for $97 plus tax and battery fee.
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
