Battery charge readings
Technically, the fully charges rest voltage should be 12.6v fully charged. The car's charging system is designed for 14.5v plus or minus a couple tenths while running. After burning off the surface charge by turning the lights on or cranking it a few revolutions without starting the voltage should still be above 12.0v. Anything less indicates a failing battery.
Both your running and rest voltage seems low. Most auto parts stores will do a free battery/charging system check.
Charlene n John
09-28-2015 06:01 AM
