Battery clamp warm
Old 09-12-2015, 11:11 AM
oyster's Avatar
Default Battery clamp warm
Hi all.
After reading some posts about poor battery clamps, I decided to check mine.
Made sure clamps were tight, turned on ignition without starting and turned on some high consumers. (All lights and the heater fan.)
After approx. 30 seconds the positive clamp was up to 50C (122F). Other connections were at ambient temperature 20C (68F).
Changed both positive and negative thin walled clamps with some more solid ones.
Also cleaned and tightened fuses in the mega fuse module.
So now the electrical power is going to the car instead of heating the trunk.
Attached Thumbnails Battery clamp warm-20150912_173954.jpg   Battery clamp warm-20150912_174113.jpg
Jon89 (09-12-2015)
Old 09-12-2015, 12:48 PM
kstevusa's Avatar
Right On, you handled the situation properly. . Be sure to ck the neg. ground at body attachment ,JIC.
Old 09-12-2015, 01:01 PM
jimbov8's Avatar
Certainly a much better clamp than the one on the left. A light smearing of petroleum jelly will also help to keep the corrosion at bay.
Either way, good job.
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
Malihide
04-02-2016 04:05 PM
Iain Yates
09-16-2015 06:48 PM
chatmanx
09-11-2015 07:17 PM
Quick Reply: Battery clamp warm
