battery disconected
The window memory will need to be reset. With the door closed, hold the 'down' switch for a few moments past reaching full down until you hear a 'click'. Low volume 'click'. Hold the 'up' switch for a few moments past full up until you hear the same click. Same for the other door.
Fuel trim will take a few miles to reset but other than that you are good to go.
