battery drain after 2 days and no start?
How old is your battery? Have you had a load test done at one of your friendly local auto parts stores?
There have been several parasitic drains identified but perhaps the most common one is leaving the key in the ignition. That prevents the car from going to 'sleep'. You should not have more than about 30ma drain with everything off. 'Off' only begins a couple minutes after removing the key and closing the doors. More than that and you get to start pulling fuses to see what is causing the problem.
battery is an interstate and a year old
tested (including load tested) at advance auto and checked out AOK
I don't eave a key in my ignition
I read about the ignition key door and trunk lights staying on (how do I determine if trunk lights stay on??) I have a 2 amp battery charger on battery and it rarely goes to full charge...any ideas appreciated!
Charlene n John
09-28-2015 06:01 AM
