Battery drain on my Jaguar 01 XK8 overnight
Welcome to the forum. Please visit the new member area to introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
First, even new batteries can fail. Check the voltage with the engine off and the lights on. It shouldn't be below 12.4v and shouldn't show any signs of dropping over several minutes. A quick test by an auto parts store will confirm that you have a good battery.
Leaving the key in the ignition switch keeps the security system 'awake' and provides a higher level of battery drain. Similarly, the drain continues if the spring loaded key slot cover does not return to a closed position with the key removal. This should not affect a good battery overnight but will over a few days.
Beyond that you will need to identify which of a large number of circuits continues to drain current with the engine off. A way to do that is to remove the negative battery cable from the battery and measure the current flow between the battery post and the cable. Something like 30 ma is normal after a couple minutes. Then you have to start removing fuses to find the offending system.
Let us know what you find.
ehogue (07-03-2016)
FS[LowerAtlantic]: XK8 throttle body
batroute
04-20-2016 10:46 AM
