battery not charging light....can i change the instrument cluster?
The battery not charging light and message was coming up frequently and the mechanic traced it to a slowly failing alternator which has been changed.
But the light still appears sometimes and it has been suggested that the instrument cluster (the 3 big dials behind the steering wheel) are at fault.
I have found a secondhand cluster for not much money - can i just take the old one out (as shown here)
https://www.jaguarforums.com/forum/s...ght=instrument
and put the repalement one in?
or is it much more complicated than that - do the clusters have to be programmed to the car....will the car have an electrical melt down if it doesnt have its original cluster?
mine is a 1997 - i've seen another '97 cluster from an XK8 and a slightly cheaper '99 from an XKR.
Is this feasable?
Is this feasable?
rsa760041
23
09-25-2015 01:33 PM
carcycle
09-07-2015 10:22 AM
