Battery recommendations
Hi all,
Our XK8 is going into the workshop to change the dreaded tensioners and timing chain. At the same time we will give her a nice oil change, replace the aftermarket radio for an original with cd changer.
One thing I want to do at the same time is change the battery for a new one. The existing one seems fine, but I hear that the battery can be the cause of many problems.
Is there a particular brand/rating that you can recommend? I just want to put the best that I can to avoid any electrical gremlins related to voltage.
A reliable battery is a must, but, fortunately, our cars seem to be able to broadcast early signs of trouble. Typically, upon starting the car, an error message about TRAC/ABS that subsequently goes away is such a sign. Mine lasted MONTHS before actually failing outright. If you have no such messages, I'd say keep using the battery you have and already paid for, one way or the other.
If you have a conventional battery (sometimes misleadingly labeled "low-maintenance"), it normally requires once-in-a-while adjustment of the acid level by adding distilled water. These adjustments can add a fraction of a Volt to an aging battery and extend their life even further.
If you just want to change it, I'd say go with the better quality AGM type (labeled maintenance-free). Some of us have had great luck with Bosch. Pep Boys in the US periodically has pretty phenomenal coupons for these, FWIW.
Best of luck, keep us posted.
I replaced mine with a Varta battery and it's working really well plus it was dirt cheap. I paid under Ł100. This is their battery finder, just put in your plate number Car battery finder from VARTA® - Find the best and most reliable battery for your car (varta-automotive.com)
Received 1,700 Likes
I put a NAPA branded AGM battery in my ‘02 XKR . Not too pricey and no complaints.
$204.99
https://www.napaonline.com/en/p/NBP9...dInput=battery
whatever battery you’d choose, keep it on a battery tender whenever the car is not in use overnight or longer . That is key for keeping the electrical gremlins at bay in these cars. I use the Deltran Battery Tender plus, many in the forum use the CTEK brand. Either one will do the job.
Z
$204.99
Z
MeatBag
06-20-2016 02:39 PM
