BBS 20 " wheels
When I looked closely into the hole, I did not see any screw threads for screwing the bolt in, it looked like a hollowed out hole that originally had a pressed in bolt head. The hole was about 1/4 to 1/2 inch deep. I will take it to Tire Rack and have them look at it. If part of the rim is attached buy these bolts, could it be taken off without removing the wheel? Is this piece made out of plastic? I noticed that It had a little curb rash which took off some of the paint on the edges which looked like plastic and not metal. According to the BBS web site they are the OZ Superleggera III wheels.
Bill
Bill
I posted a thread about one of my 20 inch BBS wheels missing one of the spline bolts and the article from XKRACER helped a lot. Apparently the bolt head broke off when the last owner had the tires replaced before I bought the car. It would appear, to fix this problem, that the broken bolt would have to be removed. All the rims are in really excellent condition except for the broken bolt head. I was thinking of gluing a similar type bolt into the hole and forget about the problem until the next tire change. Any other suggestions?
wcnesta
03 XKR
01 XK8
wcnesta
03 XKR
01 XK8
scooternva
19
10-27-2015 02:14 PM
lickahotskillet
09-11-2015 07:54 PM
