BBS hidden valve stem cover - where to buy?
Does anybody know where to buy BBS hidden valve stem covers? Not the adapter, just the cover.
On cars with BBS hidden valve stem wheel designs, each stem has a cover (see the attached picture). I lost one, not sure how, maybe it got loose and dropped while I was driving ....
Just noted that, since I am about to get a set of new tires installed.
If you can't find a US supplier, postage costs on such a light item wouldn't be bad from:
SB Wheels
They are shown under the BBS menu.
Also supplies knurled valve adaptors for these wheels which are much easier to fit and remove than the ones originally supplied.
wcnesta (07-18-2012)
Thanks Graham. I did try SBwheels - they have the adapter but out of stock on the cover. They don't have an ETA either - and they're not optimistic since BBS does not make those anymore - according to them.
I will start looking at the local Hubcap Annie.
On a separate note - I found that UK-based parts dealers can source some of the unique Jag parts much better ...
Thanks for that info.
I tried the UK importers ( BBS Alloy Wheels (Alloys) UK ) for covers and adapters before going to SW Wheels. According to them the covers were out of stock. I didn't realise they are no longer available and unlikely to be remanufactured.
I don't think these show up anywhere on the link you provided but a couple of years ago I called BBS-USA and the guy I spoke with said they had the valves and screw on covers for the valves.
Doug
I found them!
http://www.sfxperformance.com/catalog/Wheel~Accessories/Valve~Stems/page_1.htm
I did try BBS directly as well - but seems like different people get different results. I called them twice (recently and some time ago for the adapters), and both times I was told that they are not selling directly to end customers. Other members sometimes have better luck - depends on who picked up the phone I guess ....
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
GGG (02-16-2012)
I found them!
I did try BBS directly as well - but seems like different people get different results. I called them twice (recently and some time ago for the adapters), and both times I was told that they are not selling directly to end customers. Other members sometimes have better luck - depends on who picked up the phone I guess ....![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
I used the contact form on the link oldmots and seismic guy posted but haven't had a response from BBS.
I'll order a spare set of covers before they go the way of the dinosaur.
When I double click on the link in your post it opens the SFX Performance website at the right page!
You must have something set in your HTML preferences or AdBocker that's stopping it opening.
jamjax (02-16-2012)
Hey G;
Now it works...
Do you think this is the correct valve cover for BBS wheels?
http://www.sfxperformance.com/parts/BBS0915073.htm
.cheers,
jj
Now it works...
.cheers,
jj
It looks right.
The ones fitted to my Sepangs are 6mm across the top and 5mm overall length whic has to be a universal or multi-application fit.
The Jaguar toolkit has a plastic tool for removing the covers. These also are no longer available but I can't find them on the SFX site.
jamjax (02-16-2012)
I'm not sure what "plastic" tool you are talking about. The "official" kit from Jaguar that you might be able to get from some of the OEM providers includes a couple of extra valves, a couple of the screw caps, a METAL "tool" to screw/unscrew the caps (a penny works just as well) and a leatherette case to hold everything. I think this cost me about $35 when I bought one a few years ago and I think I have seen them on ebay or other places.
Doug
Doug
Doug
Doug
The photo is my Jaguar 'official' kit for the UK market. The cap tool is the dirty red thing above the valves:
![BBS hidden valve stem cover - where to buy?-xk8-bbs-wheel-kit.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/16894d1480966383t-bbs-hidden-valve-stem-cover-where-buy-xk8-bbs-wheel-kit.jpg)
It has a bar in the end to fit the slot in the caps. The bar is broken.
Is the one you have the same thing in metal?
Hey Graham,
The kit I have has a flat "T"-shaped piece of metal that is used to screw or unscrew the valve cap. If I get the chance I will take a picture but I think I have seen it pictured on some of the OEM resellers. The T-tool really does not work any better than a penny (I keep a penny in the little leatherette case).
Cheers.
Doug
Cheers.
Doug
