BBS Two Piece Wheel Ring Replacement
Left rear wheel 20X10 was returned by Dick at Coventry West late last week. He returned it squeaky clean barrel and all with a fresh stainless ring unmarred from shipping UPS ground thanks to his great care in packing. He probably used $10 or more in packaging material. The package weighed 53 lbs and cost about $60 for the round trip from Houston.
Dick pulled off the spider removing all of the titanium (titanium bolts? WTF?) studs but stripped the aluminum (aluminum?WTF?) air valve assembly in removing it. It took almost two weeks to get another from England but at least he was able to get it out without harming the wheel. He reports that the new air valve is stainless.
New Stainless Ring $270.00
New Stainless Air Valve 75.00
Labor 100.00
Shipping 60.00
Would I do it again? Only if I’m forced to and Dick Maury is still working for Coventry West. Would I try this myself? Probably not. Not only is the removal of the titanium studs problematic but they are expensive if you break or strip one. In addition the remaining aluminum air valves in the other three wheels present a real challenge to someone who’s never had much luck with the “easy out” tools. I’d hate to have to try that on a hollow aluminum valve insert. Dick didn’t say how much trouble it was but I can imagine his $100 labor fee was completely justified by the time he got done with it.
Bottom line, Dick and Coventry West did a great job for me. I do recommend them if you have an issue with the POS BBS two/three piece alloy wheels.
dick@coventrywest.com
Also…THE CLICK IS GONE! As I suspected, it must have been the damaged ring flexing and making that noise on every rotation of the wheel.
Labor 100.00
Shipping 60.00
Wheel Ring replacement
Glad the click is gone. Just a couple of thoughts. When the wheels are assembled, loctite is used. Not sure how strong but it takes a two foot long 1/2" drive breaker bar to break the bolts loose. I put them back with blue loctite and torque them down to 12 lb/ft. The trick is to go back and forth and around about three times to make sure it is settled into place. Also, if you use any glue on reassembly, make sure it is not keeping the hub to wheel apart. Not sure why they use glue as the ring is securely held into place. Most likely, when initial assembly, the glue was separating the pieces or they were not torqued into place before the loctite set up. This would cause the bolts to appear tight but the halves would not be securely fastened allowing slight movement. Before anyone gets to paranoid, this is the first one that needed a new bolt or air valve fitting. They usually come out just fine although tight.
I have taken 20" BBS wheels apart many times and never had a problem (touch wood)
As a little tip to keep costs down, what I do is contact many of the Jag breakers about and buy buckled or damaged wheels just for the spares, I have never paid more than $30 for a damaged wheel but the bolts are worth their weight in gold
RCSing,
I followed the procedure found here
http://forums.roadfly.com/forums/jag...8893108-1.html
you will need the torque wrench when assembling so you don't over tighten the bolts.
Received 2,190 Likes
This thread is a little stale but I wanted to post here some information I found. I spoke to a large company in the US that does BBS wheel repair. They informed me that because they trim ring/ band is stainless steel, they can polish it in some cases rather than replace it. I confirmed this with BBS. They recommend that once its been polished that you clear coat it as that is the way it comes from the factory. If it is bent, thats another issue but scuffed can be an easy fix. There is currently a set on ebay (18's) that the rings have been "diamond polished". Search Jaguar BBS on ebay and you will see them. They look good.
xjrjag
10-27-2021 11:48 PM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
sorken88
08-28-2015 04:09 AM
