BCM/BPM
BCM/BPM
Hey I've got a 2002 Jaguar xk8 and I need a BCM with the part number LJE2500AD-164, the issue is, I am having trouble finding a module that has a matching vcat number (last three digits). Does anyone know of anywhere I can find a module with this number? I've tried eBay a few times but all of them either have the VCAT number 163 or are unmarked. Thanks
The problem is that most breakers don't bother to copy the 3 digit number from the VCATs label onto the module, so you have no idea what it is. The best you can hope for is to try and find one from a coupe or convertible as appropriate with the matching module number and ignore the XXX. Any missing options can be programmed by WDS.
I would want to be 100% sure the problem was in fact with the BPM before buying a replacement - people seem to forget to check things like fuses, relays, switches, wiring and ground points, before deciding it must be the black box.
fast feline
07-30-2023 10:51 PM
