belt tensioner idler pulley on 4.2
Received 2,397 Likes
Are you just after the pulley? How does this assembly compare size wise? Looks correct. Only £15-56 incl
http://www.ebay.co.uk/itm/CADILLAC-S...wAAOSwNRdX4~4a
There is a better picture of it here http://www.oreillyauto.com/site/c/de...0074&ppt=C0007
Received 6,324 Likes
Looks like British Parts have the whole unit and pulleys. https://www.britishparts.co.uk/t/jag...lts-tensioners
RaceDiagnostics (09-27-2016)
It looks like you have metal pulleys. If the bearing in the pulley has gone, they are generally a standard size. I have successfully pushed a bearing out of the pulley on a Mazda 6, and then pushed a new bearing in, using nothing more than a couple of correctly sized sockets and a vice. In the case of the Mazda 6, the bearing was the same as the front wheel bearing on just about every British motorcycle made since 1950. The bearings are available on Ebay, even the good makes for about £5.
I've just been out to the garage and pushed the bearing out of one of the plastic idlers that I've just replaced with metal ones, and the bearing is a 12mm (wide) x 40mm (dia) x 17mm (hole), it's known as a 6203. Add '2RS' suffix to the end and you get a 6203 2RS bearing which means it has seals on both sides. It may be the same size as the bearing inside a metal idler, but it might not! A good vernier and google is your friend on the info re bearing sizes.
Good luck.
Good luck.
The two pulleys look totally different, luckily both are still in good condition so I will refit and look around for cheap alternatives. Once you have done it for the first time futures swap out will be easy. I'll also look out for the bearing option.
The US prices seem to be much cheaper than the UK ones.
FS[SouthWest]: XJ40 LF Diagonal Belt, Passive Restraint
motorcarman
09-26-2016 11:17 AM
