Bench Test Throttle Position Sensor
Hi all:
I purchased a used TPS b/c I/ trying to avoid buying a new or used Throttle Body. Are there any test I can try without installing it in the car to see if it's likely to work. For example, can I measure the resistances across pins. If so, what pins and what should on expect as values? Thanks
04vdp
22
02-08-2018 08:29 AM
