Best Oil filters
Best Oil filters
I recently linked from this forum into a page where someone had evaluated oil filters....a significant evaluation where he had cut and measured the filter elements....etc.
I can't seem to find the link.
Does anyone know what I'm talking about? If so, can you please point me at it?
tnx
tnx
Received 10,952 Likes
I'm usually a bit non-chalant about this sort of thing but I've heard great things about the Baldwin filters. Apparently they have a great reputation.
I never heard of 'em until I started dabbling in Ferrari servicing....which, judging from your signature, is how you learned about them as well
In a test on every oil filter, known to man including Jaguar,the Bosch premium oil filter.
has been deemed the best in the world.
YOU AINT FIND ALL THIS INSIDE A JAGUAR FILTER.
Exclusive FILTECH media technology
Screens out more harmful contaminants for greater engine protection
Stronger steel baseplates and housings
Prevent warpage, leaks and poor fit
Silicone anti-drain back valve
Ensures a supply of clean oil when you start your car
High lubricity gasket design
Provides a tight seal, yet easy removal
Double-locked rolled seam
Forms a leak free canister
CHECK OUT http://www.boschautoparts.com/Filter...s/Filters.aspx
The following 2 users liked this post by aode06:
Bob OB (11-07-2013),
MFoncerrada8 (11-07-2013)
In the real world, the Bosch listing for the 4.0L engine differs in dimensions from the Jaguar original part. It is shorter so that it will fit both the side mount filter pad and front mount filter pad applications. This bit of catalogue number engineering lets them use one part to cover two interchanges. They are also much lighter new than the equivalent Mann filter.
No thanks. Bought two, used two. Not buying any more.
Thanks for that Plums, and noted, I have a genuine Jaguar filter which hopefully will be fitted late next week when I get the tensioners done ( weh hey ) together with fuel filter and drive belt. It will give me a chance to test the gearbox also. BTW are you on the edge U.K or US? LOL's
Cheers,
ArtyH
Cheers,
ArtyH
aholbro1
08-05-2021 05:02 AM
axr383
09-18-2015 11:19 AM
