Best place to get suspension bushings?
I'm not sure about the best place, but I have Powerflex bushings in my XKR. I purchased them 2 years ago from the U.K. because I couldn't find them in the U.S. I have provided the web link for the (new to me) U.S. site.
http://store.powerflexusa.com/jaguar-xk8-p1182.aspx
I would not discount the poly, the ride changes very little and they will las a lot longer meaning your alignment will stay true longer as well.
As far as OEM type (you definitely need the OEM type with the sleeves where they are applicable) I would try the usual suspects:
- jagbits.com
- welshent.com (they are not listing bushings ob there site but I'd call them).
Jaguar OEM sway bar bushings are about $13 each. Upper mounts, sorry don't know. If I were to do it again, I'd get the poly for the sway bar, and even the control arms too. The OEM rubber doesn't last as long.
I measured my XK8 sway bar and was going to try the red poly bushings, though not 'custom' like polyflexusa's, but only 1.5mm smaller than the bar IIRC. I do have a link somewhere and the information about the sway bar diameter in one of my many threads.
Here's a repeat from another thread ... (note: this is for OEM type rubber, not that fancy space-age stuff you kids like so much).
Do you have access to a hydraulic press?
If you're going to tear apart your front end, you could replace the items that chronically wear out:
Upper shock mounts
Lower shock bushings
Upper and Lower ball joints
Upper and Lower Suspension arm bushings
... and while you're in there:
stabilizer arm links
stabilizer arm bushings
steering rack bushings
steering tie rod ends
This basically gets you a new front suspension.
Total parts cost ~ $520 from
http://www.britishparts.co.uk/.sc/ms...ing-Suspension
Upper shock mounts
scooternva
20
09-27-2023 11:25 AM
Andrew Fanshawe
09-14-2015 07:40 PM
