Billet shifter plate arrived! Stunning! 6 Speed
The following 2 users liked this post by hm1:
reb1999 (07-30-2016),
User 070620 (08-02-2016)
I think he's also got them for the 5 speed cars.
http://m.ebay.com/itm/Jaguar-XK8-XKR-6-SPEED-Billet-Aluminum-Trim-Plate-/302014976178?nav=SEARCH
Jaguar XK8 XKR 6 Speed Billet Aluminum Trim Plate | eBay
Will update with pics very soon, I had to put small washers to lift a section----to get everything flush. Looks stunning now!
User 070620 (08-05-2016)
Quick tip: So that it looks as factory perfect as possible, all the lines need to line up flush. I placed a few washers under the center console wood panel to bring it up level. If you don't do, it will look like it's sitting on top of the bezel, not an integrated factory part. Details, make all the difference
Raising console a fraction
Nice and flush
Nice and flush
User 070620 (08-08-2016)
I was going to do a complete how-to, but my shifter area was cracked in 6 places. I had to first glue it all back together before I could even start this mod.
Goes on top, that's why it ends up slightly raised. But when you put a washer or two under the wood panel, it will be nice and flush.
I was going to disassemble the piece are remove the old PRND plate.
Thanks!
dsd
Yes, I'm sure it can be taken off--it's got two screws holding it down from the underside. In order to get to them, you would have to remove the entire assembly.
Got mine yesterday.
If you try and remove the old top plate it cracks and breaks. Sigh. Should have asked first.
Yes there are two central screws underneath in line with where the numbers are above.
It is not possible to unplug the circuit board with the lights on at the gear change location. So the new one has to go on over the top of the old one.
You have to drill two holes. Fortunately there are two plastic guides under the old plate that show you exactly where to drill.
Happy to say it looks gorgeous.
I have ordered a replacement black plastic one in case I have to return the car to stock.
Very happy Sailor.
Mark B.
Very happy Sailor.
Mark B.
