Black Button under accelerator pedal
I have a 2005 XK8 that had the black button that slides down on a post undern the accelerator pedal in the glove box. When I found out where it went I replaced it to that position.
My question is, do I need to reset the throttle position sensor, It does restrict pedal travel.
If so, how do I do that?
Jack
Jack
You need an OBDII reader so you can see the throttle position but once you have that hook it up remove the black button under the throttle pedal. Open the bonnet and under the left hand side looking at the car front on so on the drivers side if you are in the UK or the right hand side if you are in the US there is a black cover over the corner of that side lift that up and under there there is a black box with a cable running to it, open the black box up and there is a ring and a cable with grooves on it with a painted section on it, Detach the hoop so it can move freely and then adjust it to where the OBDII reader says the position sensor reads 100% when the throttle pedal is at the new full travel. I'm not the best at explianing it but that's the jist of it.
The following 2 users liked this post by Kuddlesworth:
Johnken (05-25-2023),
Timeisrelative (05-27-2023)
Jack
The following 3 users liked this post by JagV8:
"It" was there long before 2001. It's primary function may have changed but all 4.0 litre XKR's are fitted with kickdown switch in that position and the circuit wasn't deleted for XK8's until vin 024687.
As stated in an earlier post some form of positive stop is a good idea for fly by wire pedals, they can and do break with heavy foot applied.
Interestingly, if one pushes the pedal with the fingers, it is possible to feel two separate functions. Simply from the way that it feels, it seems at least on my car that the kick-down/start-up fuel cutoff is within this second much shorter step of the pedal travel. Makes me wonder if the reliability of the button switch was questioned due to things such as carpet and floor mats, and it being simpler to make it a part of the drive by wire hybrid cable system.
