Black hole in key
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I'm pretty sure I already know but, I noticed my spare key has a little black hole in the back corner and it doesn't seem to do much of anything anymore. I would guess this means the electronic mind is taking a holiday huh? Any hope of restoring it to its former glory or is an expensive trip to dealer in the offing?
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
If you mean that there is an actual hole, it means the cap and the transponder chip have gone missing. Without the transponder chip, the key will open doors, trunk, glovebox but will not start the car.
If you get a new key, or a replacement transponder chip, they will have to be programmed to mate with the security system, and all keys must be present at that time.
The chips can be had, but more trouble than they are worth because they changed generations. You would need to know which one fits.
If you can get a junk key from the same year then you can dig out the chip and insert it.
You would still need to have it programmed unless you have access to the dealer level software.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
deanh
09-06-2015 08:20 PM
