Blackened headlight innards -05 xk8
![Blackened headlight innards -05 xk8-image.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/125487d1455469143t-blackened-headlight-innards-05-xk8-image.jpg)
Just purchased my " beauty"
However I haven't gotten an answer even from my PPI tech as to what happened inside the headlight housing to cause that ugly black
burnt looking residue...!!
Light works fine....
I imagine only recourse is an expensive replacement unit😟
Any help would be appreciated
Thx
Attachment 125487y
I imagine only recourse is an expensive replacement unit��
Thx
Thx
There must be condensed water in your headlight, it peeled the chrome-coat away.
Special repairshops can recoat it.
Nothing to rust, all coated plastic.
The inside of the headlights are not metal, they are plastic coated with chromium(?) If you remove the headlight lens (pain in the butt...) you can clean, or re-spray the interior of the headlights to the color of your choice. Make sure the coating you select can take the heat though, those lights will get prrrrrrretty hot on summer days if you chose a dark color
dubgw (02-15-2016)
The headlights are made of plastic housings with some sort of silver coating. This coating is very delicate, and can be wiped off very easily ( ask me how I know).
You have two options, replace that part of the housing, even on eBay that'll be around $200 a side, or go the way of the last production years and black out the main section. Do some research on 05 and 06 year headlights and you'll see what I mean.
Regards,
Regards,
dubgw (02-15-2016)
True.... It's the front part.....anyone have a "probable cause"
I would hate to have it happen again.....drivers side is perfect!!
No water condensation ever shows in the bad lens so I have to think its heat
related.... But how/ why would the chrome coating melt/ peel of like that????
New replacement lens found for $ 225 but I can't do labor myself so expense grows!!
Look for a company like this
reflektor neu verspiegen
or this
http://www.ebay.de/itm/Jaguar-XK8-XK...sAAOxykUZTfRNO
or this
Yes but I believe the cause is still moisture and should also look into his seals on the headlights as far as painting the area of the discoloration you can check into Alsa coatings Alsa ChromeFX - The World's Most Exotic Finishes
dubgw (02-17-2016)
White Bear
02-15-2016 05:18 PM
