Bleeding brakes . . .
My 2003 XKR needed brakes when I bought it. I replaced the front rotors and pads. No problem. Well, actually there was but that's another story. Anyway, I bled the front right caliper first. No Problem. On the left (drivers) side, I can't get the air out of the inner bleed. The outside is fine. I'm using the vacuum method. Checked to be sure the connection is holding vacuum with the bleeder closed. It is. Tried a different bleeder fitting. Same result. Any idea what the problem might be?
Usually disc brakes will self bleed if screw is left open until fluid runs clear. When using a suction bleeder as stated above it is almost impossible to tell if the air is from bleed screw threads or actual brake air. Of course todays sofisticated anti lock systems may change my old school knowledge.
petemohr (05-08-2019)
Received 1,686 Likes
Z
The best way to bleed brakes is to use a pressure bleeder. This makes it much faster and lessens the chance for air in the system. A Motive Products pressure bleeder is only about $50 . I usually bleed brakes starting at the caliper furthest from the master cylinder and move closer each time.
snooktarpon
05-20-2008 01:54 PM
