Blocked Cats
Blocked Cats
Hi everyone not had much sparetime lately and not been using the machine much.
The engine management light came on so I took it into the Jaguar garage where I bought it,still under guarantee thank God.
The cats were blocked would have cost approx £2000 to fix.Done 77,000 miles is this normal at this mileage?
Good to be back Al
Good to be back Al
Ah! What a wonderful opportunity to replace those awful, restrictive factory cats with something extraordinary. And for less money than your dealer wants to charge you for factory replacements.
Here's what you want:
2000-2002 Jaguar XKR Downpipes - Nameless Performance
Hopefully your mechanic figured out why they failed in the first place. Losing their effectiveness is one thing ( somewhere after 130k or so) but clogging is a sign of something else wrong - excessive oil burning or excessive fueling. Whatever the cause, unless it's corrected you're in for a repeat.
Check the fuel trims for excessive fueling.
Case in point: my Lincoln never had issues, other than a weak battery. Changed it out after a few weak starts, never thought much more about it. Some time later I heard rattling underneath while running, found both cats as the cause. Knowing that cats don't go bad by themselves I hooked up the scanner and found both banks @ 30+ fuel trims. No codes (supposed to set when in excess of 10+/-), I reset trims and allowed car to re-learn. Both trims o.k. afterward. Have to assume weak battery, exacerbated by cranking at low voltage, wigged-out the ECM and created the condition. Once the trims were re-learned no other problems have surfaced.
Excessive fueling or oil burning (too many hydrocarbons) causes the exhaust to overheat, resulting in either the catalytic substrate melting and fusing into a impenetrable blob or the shell expanding and substrate coming loose and rattling around until it breaks up and clogs downstream exhaust.
Degradation of the coatings inside a cat' can render them ineffectual and set a code but that does not cause them to melt/fuse/rattle/disintegrate.
