blown 97 engine, fitted 2000 engine
I bought a 2000 model xj8 engine for my xk, on comparison the injection system has been updated, my question is what is the vent ,breather pipes in the middle of the injection for and where does it go behind the throttle body, Or should I reinstall my 97 injection system??
The 2000 AJ27 engine is not a direct replacement for the 1997 AJ26.
It can be made to work but requires significant swapping of parts. Here is a link to get you started on what needs to be done. There are others that a search will produce.
AJ-V8 Engine compatibility question - Jaguar Forums - Jaguar Enthusiasts Forum
Good luck!
Good luck!
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
