Blue Cat tired of warning me, wouldn't start
Just thought I'd share this in case anyone else ever has this problem.
I got in the blue cat to go to work this week and she would not start. Did all the usual diagnostics, cussed and pleaded to no avail.
I decided to check to see if there were any codes to give me a clue (there weren't) and while I was plugged in, deleted a CEL light that had been on for nearly a week due to a leak in the lower part breather hose.
Amazingly, it started right up after that. I guess the cat had felt she had warned me enough and was disabling herself until I fixed the problem. I think I better pull that hose out of the trunk and replace it before she gets really mad.
Just thought I'd share this in case anyone else ever has this same problem.
Jon89 (07-30-2015)
I know my battery is putting out just below normal amps or what ever it is called and from infrequent time to time my windows loose settings, or another odd ball electrical thing happens. All symptoms of a old battery which mine is. I am going to chalk this event to that battery being old.
