Blue Crystaline Puddle
Friends:
I came into the garage housing my '98 XK8 and found a little pool of blue water underneath the drivers side headlight housing. At first I suspected coolant but it was the wrong color. Then I remembered the goofy headlight washer and suspected that a leak in this system might be the culprit. I looked it up in JTIS and I think that is where the washer pump in located anyway hiding inside the wheel well. Any experience out there re-sealing things in there to hold the fluid in place?
Dave
Dave
