Bluetooth with ISFM2381/ISFM2351 kit
Bought one of these $150 ish and thought it would be easy to install, and so it was.Took centre console out, just 4 screws, two at the rear and two at the front, after taking the jgate apart that is.
Didn't bother undoing the armrest as it comes out with the rest of the unit.
Removed the radio and plugged in the Aerial divert banana plug and socket with the kit.
https://drive.google.com/file/d/1Jcl...ew?usp=sharing
Fed the Bluetooth unit just under the Jgate on the RHS by the gear cable. Then took the power from the cigar lighter wires with shockie connectors. Soldered the button supplied, and fed into the ash tray.
https://drive.google.com/file/d/1M5N...ew?usp=sharing
Then I drilled the coin slot and fitted the mic
https://drive.google.com/file/d/1MDM...ew?usp=sharing
Bingo, all works great.
Very simple installation and works very well. 98.1 FM.
No interference with radio, no noise, clean and signal. Works great!
DavidYau (06-29-2020)
trosty
07-29-2016 08:01 PM
MidlifeXJR
Audio/Visual Electronics
07-10-2010 04:49 PM
